SailNet Community - View Single Post - Southern Cross 31?
  #33 (permalink)
Old 09-14-2007
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Nothing, unlike less expensive foams normally used on power boats and airex is a cross-linked closed cell foam so the water stays pretty much within that localized area where it got access. There is a slight exception to that in areas with a large number of freeze thaw cycles, where the melting and refreezing water can cause a delamination between the foam and the skin. Unlike Balsa this is a pretty easy repair accomplished by drilling holes, draining the area, drying it out and injecting with resin.
The nice thing about airex is that it has a little bit of memory which greatly increases impact resistance over a non-cored hull.
