The mast steps add weight aloft, and tend to snag halyards and such. I'd second the use of a good climbing harness. Spinlock sells one that is actually made by Petzl, a climbing gear company.
One obvious advantage of steps is that you can go aloft without assistance, but you can do the same thing using a climbing harness and two ascenders, and a webbing strap.
If you do install mast steps, the fasteners should be stainless steel... aluminum is really too weak for this purpose, having less than a third the strength of stainless. However, any installation should use plenty of TefGel, LanoCote or Loctite to help prevent galvanic corrosion issues between the mast, the steps and the fasteners.
