SailNet Community - View Single Post - Docking under sail... DDW??!
post #1 of Old 09-18-2007 Thread Starter
Lancer28
I'm the FNG still...
Lancer28's Avatar
Ok, I had an odd run-in with the docks yesterday. I was docking under sail (there is no motor on this boat I was using) and I was on a downwind run.
I decided to not follow the golden rule and "only go as fast as you are comfortable hitting the dock" as it was mainly a metal frame with wood for walkways. This would have been a disasterous event, as the spreaders keep this boat from blowing the main when DDW/
I turned and headed up, and just gently beached the little boat on the cove across from the marina, but this raised a question I have not had to ask before...
How do you do this? Should I have headed into the wind, and backed water with some sort of backed sail? Should I have just used the jib only and let it fly when I needed to stop?
Lancer28 is offline
