SailNet Community - View Single Post - Docking under sail... DDW??!
post #3 of Old 09-18-2007
sailingdog
The best thing to do when docking in a slip where you're facing DDW is to drop or furl the sails and let the wind push you into the slip. If you want a bit more control...keep a bit of jib up, but you probably won't need it.
Don't forget, you can bleed off quite a bit of momentum by turning the rudder from side to side...
sailingdog is offline
