Originally Posted by foxglove
I have a similar problem. I'm considering buying a chart plotter (although I've never used one) that has a built-in fish finder that I would use for depth (I don't fish either). The transducer can be mounted inside the hull anywhere I want.
The unit is about $400, which is cheaper than replacement for my Datamarine sounder.
Any thoughts on this?
Fox
I have thought the same, and the
fish finders typically give you contour of the bottom as well
You will think this is silly, but if I replace the instruments I will have to figure a way to cover the holes left in the bulkhead, ideally a fiberglass job, but I don't wanna do all that
