  #15 (permalink)
Old 09-18-2007
Sapperwhite's Avatar
Sapperwhite Sapperwhite is online now
Not So Senior Member
Sapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura about
Originally Posted by T37Chef View Post
Thanks...
Its reading all over the place, seems to calm down in water less than 10 feet but still goes from 2.5 to 188 feet and everything in between. I have cleaned the transducer bottom to make sure there was not an excess of bottom paint on it.
Funny you say that...... The ONLY time my depth transducer acted up was in the Patapsco. It would bounce between 2.5 and the true depth. It doesn't happen to me anywhere else.
Also, if you go with a chartplotter/ fishfinder combo, shop around. Many of the cos. building them make a variety of transducers for their units, both thru hull and external. You may be able to get a thru hull transducer that fits your current hole. That would make for a good winter project if you haul out for winter. Here is one example: Garmin 500 series has quite a few different bronze thru hull transducers available that are compatible with the unit. Check the accessories tab. https://buy.garmin.com/shop/shop.do?cID=150&pID=8057
I'm sure Raymarine has similar offerings.
Dictated, but not read.
