Old 09-18-2007
Valiente's Avatar
Valiente Valiente is offline
Mine on the old IOR design (long J measurement) was set for 60 degrees, but I could regularly "feather" a bit higher than that in the right conditions, to about 55-56, and I have neither a "race" bottom nor new sails on that boat. A simple way to determine this is to put a straw with a piece of tape glued to the top. Insert the straw into a piece of cardboard and affix to the deck where the apparent wind can get at it. Draw a baseline that is parallel to the boat's beam, and then draw angles on the cardboard using a protractor. As seen from above, you'll see the same thing as your windex, except that deck gear might interfere with the air flow. Probably the best place to put it would be on the pulpit, I guess...send the bow person forward to stick their head around the forestay to observe the luffing point!
