SailNet Community - View Single Post - Water in the Bilge/Keel okay?
Old 09-18-2007
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
If there is an appreciable difference between the temperature of the air and the temperature of your boat's hull, then condensation will form and run into the bilge.
It's a good idea to keep the inside of your boat as dry as you can. I'd suggest spending a few hours and getting all the water out everywhere. Then watch to see how quickly it fills up again. Also look at it after a rainfall. If you have any leaks in your deck or cabin, there will be more water in the bilge than usual.
