One check that Greybeard has missed... and hopefully one that doesn't leak... but fill the holding tank with water, by filling the head and emptying it. Freshwater is better, but seawater will also do. Once the holding tank is almost full, stop and see if you have any leaks... If you do... fix it fast... last thing you want leaking on your boat is the head plumbing.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
