SailNet Community - View Single Post - Nissan / Tohatsu 6h 4 stroke
post #9 of Old 09-19-2007 Thread Starter
audeojude
F235 Sailing
audeojude's Avatar
Originally Posted by Timrodabaugh View Post
If your old 4hp outboard is correctly proped it does not surprise me that it out performs the incorrectly proped 6hp outboard.
There is a high thrust prop available from mercury for this outboard par t# 48-812951A1
8 3/8 diameter and 6 pitch with a different blade design than the standard props
I will have to check that out. I do have the 6 pitch prop from tohatsu on the engine. Im not sure if that is the same. Ok the prop I have is 7.9 inches in diameter and 6 pitch. I'm thinking that adding to the diameter at the same pitch will actually decrease the rpm as it will take more force to turn it. However at this point I would be willing to try just about anything as being stuck with a less powerfull engine than I had bites chunks.
audeojude is offline
