  #23 (permalink)
Old 09-19-2007
sailingdog sailingdog is offline
If you can dry out the two compartments, where the limber holes are too high, then you can use a marine epoxy putty like, MarineTex, which will cure even if it gets wet. However, it does need a temperature of 70˚F or so to do so, so some heat may be required. If you decide to use MarineTex, get it as fair as possible, since it is very tough to sand fair once it cures.
