SailNet Community - View Single Post - Need material to raise floor of bilge slightly
post #5 of Old 09-20-2007
Valiente
Valiente's Avatar
Seeing as it's straight fill, you can make the first layers with chopped mat and/or microballoons. You could finish by wetting out fg tape and overlapping it up the sides of the bilge, which should keep water from ever getting beneath it
If this is a concern, however, or if you have no boat cover or you haul in a place where water is likely to freeze, consider boring a "garboard drain" to the outside with a close-fitting plug. Remove the plug in the fall and water drains straight out.
Valiente is offline
