On What???
Do you just want to test the insulation of the wire on the boat? Insulation on motor windings? There are numerous ways to test insulation. Can you be more specific?
There is a device called a Megger. It produces high current and voltage that will blow a hole in a wire where the insulation is bad. You cannot use this method in an explosive atmosphere. It can also break down good insulation if you don't know what your doing.
Let me know what your want to do and I will try to help.
Fair Winds
Cap'n Dave
