Old 09-21-2007
MikeJenkins MikeJenkins is offline
MikeJenkins is on a distinguished road
Engine starting problem
Hi folks,
I'm looking for some advice. My atomic 4 ran fine last week, but 3 days later it doesn't start at all not even asputter I have checked feul and seen it pumping into jar at carburator. I remoovded and cleaned out new carburator. There were no obvious fuel delivery problems and I have fresh gasoline this season.
I have spark from the coil to ground of about 1/4" to maybe up to 1/2". I also see a spark at each pulg when removed and held to block. I have tried lots of battery power. I do have an Indigo electronic ignition and note that LED on electronics module is not on even though I get a spark.
I checked compression in each cylinder, all were above 90 psi. I plan to check timing and distributor tomorrow any other ideas will be helpful
Thanks and regards
Mike
