SailNet Community - View Single Post - Airmar / Raymarine DST800 Transducer Issue
post #27 of Old 06-26-2014
redline
redline's Avatar
Re: Airmar / Raymarine DST800 Transducer Issue
The height of the geyser will depend on how far under water the fitting is. I pull mine to haul and launch (sling straps are bad for the wheel) and there's a gush, but I either clap my hand on it or fit the other (plug/transducer) quickly, but it's only about 1.4' below waterline. If it was a deeper hull, there'd be more pressure. Still just a moments work to sponge out the gush.
Previous boat did not have a flap, but was even shallower, so water just sort of flowed out.
Just make sure you fit SOMETHING back in the hole as quickly as possible, flap or no flap.
Sent from my iPad using Tapatalk
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
