SailNet Community - View Single Post - Composting Toilets
post #24 of Old 09-23-2007
Sailormann
Here .. Pull this
Well...here are the Canadian Regulations that apply on the Great Lakes:
Environmental Protection Act
R.R.O. 1990, REGULATION 343
DISCHARGE OF SEWAGE FROM PLEASURE BOATS
Consolidation Period: From February 12, 2007 to the e-Laws currency date.
Last amendment: O.Reg. 35/07.
This is the English version of a bilingual regulation.
1. In this Regulation,
"pleasure boat" means a boat used primarily for the carriage of a person or persons for pleasure, whether on charter or not, and whether for compensation or not, and includes a boat used on water for living purposes; ("bateau de plaisance")
"sewage" means organic and inorganic waste, and includes fuel, lubricants, litter, paper, plastics, glass, metal, containers, bottles, crockery, rags, junk or similar refuse or garbage, and human excrement, but does not include,
(a) liquid wastes, free of solids, from water used in a pleasure boat for household purposes, or
(b) exhaust wastes, cooling water and bilge water from a pleasure boat; ("eaux d'égout")
"storage equipment" means equipment of a design and construction suitable for the storage or the incineration and storage of human excrement in a pleasure boat including such equipment that is an integral part of a toilet; ("appareil d'entreposage")
"toilet", in relation to a pleasure boat, means equipment designed or used for defecation or urination by humans. ("cabinet de toilette") R.R.O. 1990, Reg. 343, s. 1.
2. No person shall discharge or deposit, or cause or permit to be discharged or deposited, into any water, sewage from a pleasure boat. R.R.O. 1990, Reg. 343, s. 2.
3. The owner and the operator of every pleasure boat in which a toilet is installed shall ensure that, while the boat is on water,
(a) the boat is equipped with storage equipment; and
(b) such toilet and storage equipment are installed so as to be non-portable. R.R.O. 1990, Reg. 343, s. 3.
4. The owner of a pleasure boat in which a toilet or toilets and storage equipment are installed shall ensure that each toilet and the storage equipment are installed so that,
(a) the toilet and equipment are connected in such a manner that the equipment receives all toilet waste from the toilet;
(b) equipment designed for the storage of human excrement is provided with a deck fitting and such connecting piping as is necessary for the removal of toilet waste by shore-based pumping equipment;
(c) no means of removal of toilet waste is provided other than the means mentioned in clause (b);
(d) equipment designed for the incineration and storage of human excrement is supplied with such electrical current or other source of heat as is necessary to reduce to ash all excrement deposited therein; and
(e) all parts of the system for removal of toilet waste are congruent with one another and the boat. R.R.O. 1990, Reg. 343, s. 4.
This is R.R.O. 1990, Reg. 343, s. 3 referenced above:
Note that the regulation states that the toilet needs to be INSTALLED so as to be non-portable WHILE THE BOAT IS ON THE WATER
This means that while your boat is floating your portable toilet needs to be held in place with a secure system that would not allow it to be moved. i.e.: it is not acceptable to use something that can be passed from cabin to cockpit, or moved around the cabin.
The unit needs to be equipped with a vent and pumpout fitting, and you need to connect this to a pumpout fitting on the deck.
The Thetford MSD Sanipotties are definitely legal, as are some others:
SaniPottie MSD marine toilet.
3.0-gallon (11.4-liter) holding tank capacity.
Permits overboard discharge, dockside pumpout,discharge into remote holding tank. Includes stainless steel hold-down brackets.
Sailormann is offline
