SailNet Community - View Single Post - Steping Mast On Deck
post #3 of Old 09-25-2007
Tartan34C
One thing to consider is the fact that a keel stepped mast is stiffer and stronger then a deck stepped mast of the same dimension. If you deck step the mast will it be strong enough? Also, and I am sure you thought of this but you need a compression post to replace the missing section under the deck. You might be better of to splice the mast and put a sleeve in it.
Good luck and all the best,
Robert Gainer
Tartan34C is offline
