yes the rotating mast works well. good for .5-1 kt. The bearing conversion works but is known for failure due to uneven pressure applied to it...but will make it rotate freely (til it fails). As long as it is rigged OK it will be fine. Manually rotate it if you like, or wait for a gust to 'adjust' it for you
