SailNet Community - View Single Post - Outboard motor charging upgrade
post #5 of Old 07-01-2014 Thread Starter
This Old Sailboat
aka $tingy Sailor
This Old Sailboat's Avatar
Re: Outboard motor charging upgrade
I don't know about Mercury outboards but they should basically be the same. You need two things on it: the generator, which consists of one or two coil assemblies; and the regulator/rectifier, which is basically a box that plugs in between the generator and your boat. There might be related wiring and brackets needed too.
You should be able to go to your Mercury dealer's parts department and they can sort it out for you. Or, you might be able to find the part numbers online like here.
Explore over 100 DIY sailboat restoration and improvement projects at
This Old Sailboat is offline
