SailNet Community - View Single Post - Interior Cabin Walls
post #3 of Old 09-25-2007
sailingdog
If you can afford the weight, then putting in furring strips and mounting thin boards for the ceilings or overhead is a good idea. Just make sure that you can remove them fairly easily, in case of a holing. You will definitely want to have a small airgap behind them, to ensure that you get good air circulation, and allow any condensation to drip down into the bilge. Unless your boat has a cored hull, the tongue and groove might be a bit too restrictive in terms of letting air get back there.
sailingdog is offline
