SailNet Community - View Single Post - Convert jib from hanks to furling?
post #3 of Old 09-25-2007
Sailormann
Here .. Pull this
For about the same amount of money you can rig a second, detachable headstay just behind the permanent one. Use a pelican hook and a turnuckle at the foot. When you are not using it (which will probably be most of the time) you detach it and run it down the front of the mast to an eye bolt.
Sailormann is offline
