SailNet Community - View Single Post - E32 Leak around stern tube for prop shaft
Old 07-04-2014
ctalmage ctalmage is offline
ctalmage is on a distinguished road
After repowering our E32 and running the boat under power for 6hrs, we discovered a minor leak near the prop shaft which we thought was the stuffing box or rubber tube on the stuffing box. After tightening all the rubber tube clamps and tightening the stuffing box seal, leak was still there. Ran the boat under power for another 1.5 hrs, leak was worse, a lot worse. Upon careful inspection, boat still in the water, I found the leak was coming in around the nut that tightens/seals the stern tube. Hauled the boat out, now time to pull the stern tube and fix the leak. Has anyone tackled this type of repair -- any helpful hints would be appreciated. Can this be fixed without pulling the shaft out of the boat?
Thanks, Cal
s/v Agave Illusion
