SailNet Community - View Single Post - 2014 Sailing Season
post #186 of Old 07-05-2014
TakeFive
TakeFive's Avatar
Re: 2014 Sailing Season
You gear was engaged and you were breaking the regulations. You principal propulsion was your sail.
The other boats you saw I am sure were doing what most other safe sailors were just like Colin, and I do using the sail to maintain balance, be seen around the many blind corners on the canal, and use the sails to BOOST their speed a little.
My principal propulsion was the motor, which was in gear the whole time but speed was within the idle range marked on my throttle. I was completely safe and compliant with the regulations. Your accusation is incorrect.
With jib up I was averaging 6 knots, occasionally as high as 6.5, thanks in part to a favorable current. Immediately after furling the jib I dropped back to 5.4 knots at the same motor setting. Your accusation is thus proven wrong.
You seem to be obsessed with picking on me.
...Just repeat after me...when my car is in gear..its not idling...when my boat is in gear...its not idling
Curb the attitude, pal.
An automatic transmission car certainly can be in gear at idle speed. It's what causes it to creep ahead when sitting at a red light. If you release the brake on a level surface, the car will move ahead at about 5 knots.
Rick S., Swarthmore, PA
TakeFive is offline
