SailNet Community - View Single Post - Neat Product: Cellular on one side, 802.11 (wireless) on the other
Old 09-28-2007
sailingdog sailingdog is offline
Labatt—
The major advantage a cellular router, like the one you're describing will give you is slightly better reception, because you can often position the router more easily, and the ability to share the cellular data connection with multiple computers.
Danielh's advice about using the encryption and access restriction features, like MAC address denial, is a very good one. Since most cellular connections are fairly low bandwidth and some are per-megabyte, you really do want to restrict access as much as possible.
You can read about the security features and what to use for a typical WiFi setup and why here. Although I wrote it over two-and-a-half years ago, it still covers much of what is out there today. At the very minimum, you'd want to turn off the SSID broadcast, and enable the WPA-PSK encryption, with a strong pre-shared key. MAC address denial would be a good idea as well, but some would consider it overkill.
From what I understand, the ones that use a PCMCIA-type cellular modem, rather than the USB ones are better, but YMMV.
