Battery bank sizes
Thanks for the responses so for.
House Bank = 4 wet deep cells...244 amps total
Starter Bank = 1 wet deep cell...62 amps
Definitely plan on using a marine grade alternator. The API Alternator I am looking for is better sealed and intended for marine applications.
To date have not had heavily sulfating, probably due to two facts: 1.) The boat spends 99% of it's time in the slip with the shore power plugged in. However, when I start taking week long voyages the risk clearly applies. 2.) I already have a Truecharge microprocessor controlled multi-stage battery charger wired into the the boat's shore power breaker box.
I will look into the smart charger external regulator.
Thanks....Steve H.
Cam--Is there some other form of battery charger you were referring to?
Reason: added details
