Old 09-28-2007
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
Steve...no...the Truecharge models are good chargers...all except the 10 and 10TB have an EQ cycle as well and if you've never used it, it is a good idea to do so once in a while...I used to do it monthly when I was living aboard.
That said...the fact that you are plugged in with a good charger 90% of the time leads me to think tht our batteries shoul be OK. With a roughtly 300 amp hour total, you need an alternator in the 80-90 amp area...anything else would be overkill unless you plan on further enlarging your bank or switching to AGM's which can accept unlimited amps. A 200 amp alternator will NOT charge your batts any faster than an 80Amp one given your present size and configuration.
With your size house bank...244A/H's...you can use 122A/H's before you need to recharge. Your battery bank will ACCEPT about 60Amps of current in bulk charge stage so you can recharge to about 90% full in about 2 hours of engine running time with ANY alternator over 60 amps.
If that is not quick enough for you...your only alternative is to changeover to AGM batteries and a 120amp alternator which will get you done in half that time.
Hope this is helpful to your decisions.
