Thread: reseal keel
Old 09-30-2007
deniseO30 deniseO30 is offline
Denise, Bristol PA,
deniseO30 is on a distinguished road
3m 5200, it comes in fast med and slow cure. Unless there are big gaps you may have to use epoxy putty to match it to the keel first. If the keel is iron the hard part is getting the rust and scale off. Consider getting something larger then washers for the bolts. I've seen other people fix the "catalina smile" by using stainless plate.
good luck!
Denise, Bristol PA, Oday 30
