SailNet Community - View Single Post - COLD WEATHER SAILING!!!!
post #9 of Old 09-30-2007
sailingdog
No, you really need a dry suit. As CapnHand pointed out, a wet suit will tend to cool you off if you're out of the water, since the water will evaporate. The other advantage of the dry suit is that you can layer under it... and adjust for the temperatures that way. In cool weather with cold water, you might want just the drysuit over your clothes... in cold weather, you'd probably want to add polar fleece as additional insulation.
BTW, you really shouldn't revive dead threads, since it is considered poor net etiquette to do so.
sailingdog is offline
