BTW, I generally would prefer foam core materials for the hull, rather than balsa. The more compressible foams are better in terms of dealing with damage and may absorb an impact enough so the inner laminate isn't breached. It is also not subject to rot in the case of a laminate penetration, but still needs to be surveyed quite carefully.
