Originally Posted by tsingtao
Anyone have any experience with the Honda 2HP with centrifagul clutch? Looking at a new outboard and weight is primary concern. Had a dealer say stay away from the Honda because clutch engages when starting?? Any real life experience??
Not with the Honda, but with a Nissan I think it was. It was ok, but when you are at the shore, you will often have to start that motor while in the water (so you can keep your nose into the breakers before you get in). Are you ok with that? Also, that little engine is going to have to push hard to get through any breakers at the shore.
When going back to the boat, you will get used to just killing it and coming in at a slow ramming speed. Better grab the
ladder first time.
I honestly am a fan of a GOOD, properly sized outboard. It is one of the most used pieces of equipment on our boat. In a very controlled atmosphere, the small outboards are fine. However, if you are planning on cruising or will be using it on the coast wheere you might beach the dink, I think you will not be happy.
Just my real life experiences.
- CD
