SailNet Community - View Single Post - Pearson 303, P30, Flyer
Old 10-15-2002
SailorMitch's Avatar
SailorMitch SailorMitch is offline
Senior Moment
SailorMitch will become famous soon enough
The P-30 is much more performance oriented than the 303 with enough room for some cruising. The P-303 was designed pretty much for cruising. The 303 displaces about 2,000 lbs more than the P-30, and has much better accommodations down below. So as you might expect, the 30 is better under sail of the two.
As already stated, the Flyer is different yet. For example, it displaces about 2,000 lbs less than the P-30 but the sail area of the two is nearly equal.
