SailNet Community - View Single Post - I-30 water tank issue
post #6 of Old 07-18-2014
pdqaltair
pdqaltair's Avatar
Re: I-30 water tank issue
You really do need the strainer. Don't pretend otherwise; it can save the pump and prevent a lot of faucet clogging. Sure, everything will run fine without it... for a time. Shurflo makes some nice cheap ones if the one you have cannot be fixed with a new screen, which it most probably can.
It's embarrassing to remove a correctly installed strainer simply because you can't be bothered to clean it or repair it.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
