SailNet Community - View Single Post - Drying Wet Deck Core with Acetone
post #9 of Old 10-08-2007
sailingdog
The real problem is that it is very hard to accellerate drying out the core material. Even using Acetone or Alcohol isn't going to help unless the acetone/alcohol can get to the soaked areas... and unless you're planningon drilling lots of holes, you'll still have areas of core that is still damp/wet even after quite some time. Doing it properly, using heat and vacuum will help get rid of the deeper moisture, but still requires time.
sailingdog is offline
