SailNet Community - View Single Post - CG documentation.
post #5 of Old 10-19-2002
CG documentation.
I would invest a few hours time with a marine mechanic to determine if the engine has big or small problems. You invested in the survey, do the same with the mechanic so you know what you are buying unless it is so ridiculously cheap that even replacing the engine still makes it a bargain (replacing an Atomic 4 with a 2 cylinder diesel will set you back $10,000 installed - you might be able to find a rebuilt Atomic 4 for $2,500 plus installation).
JWag is offline
