SailNet Community - View Single Post - Propane leak
Thread: Propane leak
post #20 of Old 10-11-2007
sailingdog
Generally, I don't recommend using teflon tape for gas fittings. In many states it isn't allowed. You really should use pipe thread dope instead. IMHO, it is far safer. If you use teflon tape and the tape shreds, pieces of it can get in the gas line and cause leaks at valves and such, which isn't the case with pipe thread dope.
sailingdog is offline
