SailNet Community - View Single Post - cast iron keel coating
post #2 of Old 02-02-2001
munchimike
Sand as much of the metal to shiney as you can.Use a rust converter all over the exposed surface.Etch with a metal etch, or some converters double as etch. Penetrating epoxy, zinc-chromate, or other marine grade underwater primer for metal, Epoxy coating seem to last longer and hold better to metal. Double coat theareas under the foot.Shift your braces and try to move the keel pads back to access the areas that the boat is sitting on......Rev.
munchimike is offline
