  #13 (permalink)
Old 10-11-2007
tomg847 tomg847 is offline
tomg847 is on a distinguished road
Tom-
based on your photos, it looks like the stanchion base on the port side may be the cause of the leak on that side. On the starboard side, it is probably one of the screws for the hatch.
I would add a backer block to shroud and use a longer bolt. Also use a fender washer if the the backer block is not metal.
Possible. I did re-seat and seal that stanchion this summer during my leak chase. That didn't fix it. Then I found the hatch was guilty. Like you say, it could easily be one of the screws. I'm going to do some work on that hatch flange and see what I can figure out.
I'll probably take all the deck hardware off too since I want to repaint the deck too.
Tom
