Old 10-14-2007
SEMIJim's Avatar
SEMIJim SEMIJim is offline
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Originally Posted by Tartan34C View Post
Because of this damage you can have a weaker thread and you can have surface roughness that will cause galling under load the next time you use the adjuster. If you damaged it then it will never repair itself.
Yeah, that's what I pretty much expected to hear .
Without seeing what you have I can't say one way or the other
It's a pretty simple mechanism. As I wrote: Imagine a long screw hooked to the backstay. Screw is threaded thru the center of a wheel. Bottom of the screw has a rectangular block on it that is captured such that the screw can't turn. There's not much that can go wrong with it.
but it sounds like you have a problem and need to replace it. Just a long distance guess and nothing more.
I understand. And I suspect you're right . An expensive lesson in why not to forget or put off even simple maintenance.
I'll first try the lubrication. If that doesn't resolve the problem, next I'll find a competent machinist. If re-tapping/-threading won't make it usable and reliable again, maybe the machinist can fabricate new parts more cheaply than a whole new tensioner would cost. If not: Then we'll have to decide whether to bite the bullet and replace it, or just do w/o a backstay tensioner.
Thanks for your comments, Robert.
Jim
s/v Abracadabra
1976 Pearson P30
