SailNet Community - View Single Post - Diesel exhaust smoke
post #2 of Old 10-16-2007
trantor12020
trantor12020's Avatar
you probably have an air leak into the fuel system. If you've replace the 10um Yanmar filter, then check the housing and make sure you replace the O-ring with new. Check the Primary filter for leak as well. Twice I've same problem as yours, lots of black smoke & unburnt fuel. Traced to leaky fuel filter assembly (leaks air in). How that cause black smoke? don't know, go figure. Good luck.
trantor12020 is offline
