SailNet Community - View Single Post - Looked at a merit 25.
post #6 of Old 10-19-2007
kwaltersmi
Broad Reachin'
kwaltersmi's Avatar
Yes, you can varnish over the tung oil, but I've noticed that for some reason it tends to make the tung oil appear darker. As long as you let the tung oil soak in for at least a couple of days prior to applying the varnish you should be fine. However, I think I'd strip and sand the wood if I were going to use varnish.
Catalina 34
kwaltersmi is offline
