SailNet Community - View Single Post - Two piece mast?
Thread: Two piece mast?
Old 10-20-2007
Tartan34C Tartan34C is offline
Tartan34C will become famous soon enough
There is a limit to the length of an aluminum extrusion so joints are common. You will usually find a joint at the partners or spreaders because the mast is more in compression then bending at those places. A joint doesn’t always mean a change or repair was made it may only indicate that the section used for your boat came standard in a length that needed a piece spliced in to be long enough for your mast. Properly done a splice isn’t any reason for concern.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didn’t work before.
Don’t waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
