I posted that link more for the info on what to inspect on a woodie than for any info on C-Flex.
I think it was applied unecessarily on this boat to ward off borers in the warm waters of Fla. The wood was still very good with the exception of a couple of planks. The ribs are still solid.
As far as me reporting a failure on my boat is concerned. I said I found one plank with a small soft area on the INSIDE of the plank, not between the plank and the C-Flex where you would normally expect it. Having ground out the soft area, I found it did not extend to the outside of that plank, which was still dry as far as I can tell. This was not a failure of the system.
Also, I think there's some confusion regarding C-Flex and other glass sheathing techniques. Bill Seeman developed C-Flex in the 1970's, laid over 5200 to avoid the delamination issues associated with prior systems. Other systems were to rigid and couldn't flex with the wood, causing delam. Near as I can tell, the only issue is with moisture getting trapped between the sheath and the outer wood. Considering that waterlogged wood at the bottom of the bilge won't rot because rot occurs between 20%-80% moisture content, the biggest concern (to me) would be the planks bordering those wet planks. Of course, I could be full o crap too.
Regardless, we can agree to disagree as far as I'm concerned.
Would I buy an expensive boat that had been C-Flexed? Probably not. Would I spend twenty dollars on another Oh Joy? Betcha ass I would.
