Old 10-23-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
I'd second Chris White's The Cruising Multihull, and also recommend Thomas Firth Jones's Multihull Voyaging.
Also, I'd recommend chartering the boat you're most interested in as well.
I'd also recommend getting the smallest boat you're comfortable with... since larger boats also have larger costs associated with them, and also require more strength since the sails are larger, the anchors are heavier, etc.... Yes, electric winches and windlasses help to a point, but they don't do much for you when you're trying to wrestle the mainsail down and put it into a sailbag... or haul the anchor off the roller and stow it in the locker for a bluewater passage...
Finally, mistakes on a larger boat can quickly become dangerous. Having a problem with the jib on a 30' boat, you can often muscle the sail down or furl it manually. Doing the same thing on a boat that is 40' LOA isn't generally possible. A 40' boat isn't 33% larger than a 30' boat...but more like 135% larger...since boats grow in length, width and height.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
