SailNet Community - View Single Post - Sizing battery charger
post #9 of Old 10-27-2007
dohenyboy
all these confusing ropes
Okay here is illustrated a technical fact where, I believe, cruisers err.
If you have say 6 golf cart batteries (6v) with 100 amp hour ratings each and have them paired to produce 12v, at 12v usage the total amp hour capacity is only 300 amps. If you have a 6 volt system yes you would have 300 amp hours. Amps time volts equal wattage. Am I not correct?
Also. AGMs can support 30 to 40 percent charge rate, so if you want to minimize charging time you will go with the biggest charger you can with AGMs.
dohenyboy is offline
