Originally Posted by JohnRPollard
Robert Gainer: How does the centerboard of the St. Lawrence Skiff work? You said it was a "fan type" that expands. I'm having trouble envisioning that?
Have you seen someone fan out a deck of cards? You slide out the aft edge while holding the forward edge and you get a triangle that expands at the aft edge while pivoting at the forward end. If you look at the link you will see the seams and size of the case.
http://www.nextwaveboat.com/Images/s...ence~skiff.jpg
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didn’t work before.
Don’t waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
