SailNet Community - View Single Post - Partner shut off key on overnight run now engine won't run...
post #30 of Old 08-28-2014 Thread Starter
JRickW
Re: Partner shut off key on overnight run now engine won't run...
I am very confident there is nothing inside the injector, it was stripped and cleaned. What I don't know about the injector is the pop pressure and volume.
The fuel has all been replaced.
It is possible that something is going on with the throttle/governor. I will look into it a bit more.
Yes the batteries were dead after the run. That's because when the key is off, there is no field current to the alternator so it doesn't produce any voltage. The other thing with the key off is the electric fuel pump doesn't work. My engine doesn't seem to have a mechanical lift pump.
JRickW is offline
