SailNet Community - View Single Post - Bukh engines
Thread: Bukh engines
post #18 of Old 10-30-2007
Tartan34C
Originally Posted by GBurton View Post
I have found out that Bukh sells a turbocharger for the DV24 (The engine that I have) This might solve the problem that I have with the engine being too small for my boat (Westsail 32)
What are the pros and cons of turbocharging a sailboat engine?
The downside is shorter engine life and more likelihood of unexpended failure. I donít feel the need for very much power on a sailboat and in fact sometimes sail without an engine of any kind. Maybe you should try the boat before changing things.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didnít work before.
Donít waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
Tartan34C is offline
