  #17 (permalink)
Old 10-31-2007
US27inKS's Avatar
US27inKS US27inKS is offline
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
Originally Posted by Bardo View Post
Don Casey recommends adding the particulate matter to the primer, so that you will encapsulate the beads with the 2 coats of paint. Everyone concur?
It depends on the addative you use. If you're using sand, I would say follow Casey's advice. If using the intergrip, follow interlux's instructions which is to mix it in the paint, let it set for 20 minutes or so, stir and paint. I wouldn't want a coat of paint over the finish I got. It turned out perfect.
I also agree with the need for proper respirators when spraying 2 part paints. I didn't have pressurized breathing air available when I sprayed my deck, but I did use a high quality respirator for automotive painting with good cartridges. I shot the paint (took about 30 minutes per coat) then left the building. I also used an hvlp gun which put much less paint in the air than a standard sprayer. Those 2 part paints are awesome, but they will kill you.
John
