Originally Posted by TrueBlue
We have two Lavac heads on our boat, each with an integrated shower. The forward head is what we use solely for toilet purposes.
The aft head however, is ensuite with the aft cabin. It encloses a toilet with a shower valve, tiled floor and an operable portlight. The sink is in a separate cabinet within the stateroom - outside of the head compartment.
This setup makes a great shower stall and is used solely for this function.
Originally Posted by labatt
I haven't seen that model. Sounds kind of disgusting to me!
You're being fictitious . . . right? If not, then let me explain.
The forward head is fitted out nicely with teak doors on the above sink counter storage lockers and below. Not a large space but big enough for it's intended purpose. There is a 4 ft extendable hose, stored below counter and attached to a hand shower mounted above counter - directly adjacent to the Lavac. Even though there is a tiled floor with a sumped drain, we do not use this space for showering - would make a mess of everything, including the teak and two towel holders. The hand shower does serve as a means for rinsing the bowl after use.
The aft head is large and completely enclosed by high pressure laminated marine plywood. There is a tiled floor and drain, a Lavac and a bulkhead mounted shower mixing valve, with shower hose and spray mounted above. A shower curtain covers the teak hinged door enclosing this compartment . . . sit on the Lavac when showering. This is a dedicated shower stall - works very well with a venting portlight and waterproof surfaces.
The teak sink cabinet with hinged counter concealing the sink, is outside of this space - within the private double cabin.
Why does this sound disgusting?
