If they had blocked it wrong and it sat on the hard for 6 weeks like that can it distort the hull enough that the keel leans off centre?
Check the keel bolts when you haul her. Not likely that your hull is distorted but if they dropped it then the keel bolts could be bent. Take pictues of the list just in case...
Also - what side is your fuel tank on ? Is it full ? There's a fair amount of weight there. Did they take out the batteries ? Are they back where they're supposed to be ?
